i am doing simulation via Grasshopper. However, i met the following problem
stderr:The process cannot access the file because it is being used by another process.
is there anybody help me to solve the problem?
Are you sure that you don’t have any files in the URBANopt folder open in another program?
If so, does manually deleting the simulation folder and rerunning solve it?
ok, let me try first
unfortunately, i ensure that URBANopt has not opened by another program and i have tried to delete the whole simulation folder and it still have the following error:
Hey @yinlong ,
It’s possible that your language settings are interfering with the simulation. Could you try writing the GeoJSON into a _folder_ at the root of your machine. Something like:
C:\dragonfly
I have tried to change my system into English but still have error. By the way, how to change the simulation output folder in the Grasshopper, thanks. Since this is related to my final year project, which is important .
Use the _folder_ input of the HB Model To OSM component.
where this model is follow the tutorial you have uploaded on youtube
It’s there on the “DF Model to GeoJSON” component.
Hi @chris, I am encountering the same exact problem. Tried all the solutions you proposed and yet nothing is working. Do you have any suggestion?
Hi @Valeriolf ,
A lot has changed since the first post here. Are you using LBT 1.8.0 and URBANopt 0.11.1? Can you send a screenshot to confirm that it is the exact same message?
