hi,
how can i fix these errors in daylight simulation on HB+ ? the following file is my file that i connected analysis Grid to spatial daylight autonomy and annual daylight metrics but error.
annual-daylight-bsdf1.gh (478.1 KB)
thank you for help
hi,
thank you for help
After you generate test points, you need to use HoneybeePlus_Annual Daylight Recipe. Then use that recipe and run simulation using HoneybePlus_Run Radiance Analysis. The output of that component needs to be supplied to the _analysis_grid input of the HoneybeePlus_Annual sunlight exposure
