Hi everyone; I’m currently running the latest versions of Honeybee and OpenStudio. When attempting to use the Energy Balance code from Hydra, I encounter an error in the Honeybee Export to OpenStudio Component. The error message suggests that OpenStudio isn’t installed, even though it is. Furthermore, I can’t find any component for exporting in this version. I suspect this issue might be due to version differences. I’d prefer not to downgrade to older versions. Does anyone have suggestions on how to resolve this with my current setup? Thanks.
Hi @parinaz ,
All of the samples currently on Hydra are using the old legacy version of the plugin. If you installed LBT 1.6 from food4rhino or from the Pollination single-click installer, these are the sample files that you should be looking at in order to understand the new workflows:
