Im getting an error msg " 1. woirkingDir_ cannot have a whitespace in the name for THERM to run."
when i tried to run the downloaded script
Change the current workingDir
to a new path with no white-space.
@DISAM ,
If you didn’t change anything in the downloaded script, you probably have space in your Windows username. Just input the path to a folder directory into the workingDir_ input of the Run THERM component as Mostapha suggests.
thank you i will try this
How to construct composite with brick and concrete material in honneybee EP construction
