Hi, everyone
I built a window construction as the pic show below but it didn’t work. Can anyone points out the wrong part?
From the video tutorial the “window air gap” node had a “gastype” input before, how can I change the gas type in the currently version, for example, how to set to vacuum?
The last question is where can I get the whole U-value of the window construction after I correctly built one?
Thank you all for the help.
