I have a question about HB Model to OSM.
I got this error, do you know how to solve it?
- Solution exception:No file was found at C:\Users\myname\simulation\unnamed\openstudio\out.osw
I have been doing a lot of research but can’t figure it out.
What could be the cause?
I am having the same issue. I believe it has to do with some widows restrictions to write .bat files… So far no solution… :
You are using an old Honeybee component. Try updating your LBT installation and follow the compatibility matrix for correct version of Openstudio.
