Error on annual daylight analysis
Hi, i tried to do an analysis from honeybee, using rooms, shades and apertures. The issue is that when i try to let annual daylight analysis go, box turns red and says:
  1. Solution exception:
    The recipe failed to run with the following error(s):
Execution Summary
Scheduled 17 tasks of which:
  • 6 ran successfully:
    • 1 CreateDirectSky(…)
    • 1 CreateRadFolder(…)
    • 1 CreateSkyDome(…)
    • 1 CreateTotalSky(…)
    • 1 GenerateSunpath(…)
  • 1 failed:
    • 1 PrepareMultiphase(…)
  • 10 were left pending, among these:
    • 2 were missing external dependencies:
      • 1 PrepareFolderAnnualDaylight(…)
      • 1 RunTwoPhaseDaylightCoefficient(…)
    • 1 had failed dependencies:
      • 1 _TwoPhasePrepareFolder_ae79e661Orchestrator(…)
    • 5 had missing dependencies:
      • 1 AnnualMetricsPostprocess(…)
      • 1 CalculateTwoPhaseMatrix(…)
      • 1 LetAnnualDaylightEnhancedFly(…)
      • 1 _Main_7efbbeb4Orchestrator(…)
      • 1 _Main_ae79e661Orchestrator(…)
    • 2 was not granted run permission by the scheduler:
What can i do to fix the problem?
Hi @Edux,
If you still have an issue please share the Grasshopper file with internalized geometry.
