I’m getting an error when trying to produce the sky visualizations in the “watch the sky” example file. The EmbryoViz component give’s a “1. Path must be a valid location” error. The gif it is trying to reference is 0kb.
It seems the conversion to .gif is failing. I’m struggling to trouble shoot this one.
If you are not able to view your GIF file even after installing the radiance version Mostapha recommended, make sure you choose your installation location as "C:\ and not something like “C:\Program Files (x86)”.
