I am trying to run the TauClearSky Component but I get this error:
- Solution exception:Local variable ‘iron_python’ referenced before assignment.
Attached the file. All the components are updated.
Could you help me?
Thanks
Andrea
tauclearsky.gh (456.9 KB)
Working fine at my end.
Please update the HB+LB components. They are not the last ones.
@AbrahamYezioro thanks for checking.
I have updated everything but still not working. I noticed that both the WEA components don’t work (see attached figure).
Is there a solution to my problem?
Andrea
tauclearsky.gh (458.2 KB)
Check what are you missing in the installation. See the output of the HB-HB component.
You are probably missing Radiance or Daysim.
It is missing only openstudio. All the others components are installed. I don’t know what is going wrong.
Thanks for your time
I would try to install again LB[+]
It’s most likely because of the version of IronPython. Can you try lines below in a GHPython component and let me know the results.
import platform
iron_python = True if platform.python_implementation() == 'IronPython' else False
This is the output.
Runtime error (ValueErrorException): failed to parse CPython sys.version: ‘2.7.3 ()’
Traceback:
line 1382, in _sys_version, “C:\Program Files\Rhinoceros 5 (64-bit)\Plug-ins\IronPython\Lib\platform.py”
line 1418, in python_implementation, “C:\Program Files\Rhinoceros 5 (64-bit)\Plug-ins\IronPython\Lib\platform.py”
line 2, in script
Thanks @mostapha
Andrea
And are you using CPython? This is pretty strange since the error happens in IronPython. Can you also try these lines?
import sys
print '\n'.join(sys.path)
I want to see if path to CPython libraries is added to sys before path to IronPython.
Here the second output.
C:\Users\azani\Documents\00_Heintges_Projects\1504_1st&Mission\Death_Ray_1stMission
C:\Users\azani\AppData\Roaming\McNeel\Rhinoceros\5.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib
C:\Users\azani\AppData\Roaming\McNeel\Rhinoceros\5.0\scripts
@AndreaZani905, This should solve the problem:
Please updated Ladybug[+] library.
Here is why the issue was happening:
