- List item
I need help when I start Grasshopper I get this error “The Ironbug.LBHB_Legacy Component Library was build against a different major version of the Grasshopper SDK: Local SDK = 1.0.0.20 Referenced SDK = 6.27.20176.5001”
Grasshopper is still working normally but energy simulations fail to run
Do you know what might be causing this problem?
Thank you so much
Rana
