Error / UTCI-Daylight factor
I’m having error with the new update of Ladybug while using the HB UTCI comfort map
"1. Solution exception:
The recipe failed to run with the following error(s):
2024-06-26 10:04:00 ERROR: “ComputeSphericalViewFactors” failed. See below for more information:
Bad header!
2024-06-26 10:04:04 ERROR: “ComputeSphericalViewFactors” failed. See below for more information:
Bad header!
2024-06-26 10:04:08 ERROR: “ComputeSphericalViewFactors” failed. See below for more information:
Bad header!
2024-06-26 10:04:13 ERROR: “ComputeSphericalViewFactors” failed. See below for more information:
Bad header!
2024-06-26 10:04:17 ERROR: “DirectSun” failed. See below for more information:
Bad header!
2024-06-26 10:04:23 ERROR: “DirectSun” failed. See below for more information:
Bad header!
2024-06-26 10:04:30 ERROR: “DirectSun” failed. See below for more information:
Bad header!
2024-06-26 10:04:36 ERROR: “DirectSun” failed. See below for more information:
Bad header!
Execution Summary
Scheduled 78 tasks of which:
  • 46 ran successfully:
    • 1 CopyGridInfo(…)
    • 1 CopyRedistInfo(…)
    • 1 CopyResultInfo(…)
    • 1 CreateDirectSky(…)
    • 1 CreateDynamicShadeOctrees(…)
  • 8 failed:
    • 4 ComputeSphericalViewFactors(…)
    • 4 DirectSun(…)
  • 24 were left pending, among these:
    • 5 were missing external dependencies:
      • 1 RunRadianceSimulation(…)
      • 4 RunRadianceSimulationLoop(…)
    • 4 had failed dependencies:
      • 4 _RadianceMappingEntryPoint_29999f5eOrchestrator(…)
    • 10 had missing dependencies:
      • 1 LetUtciComfortMapFly(…)
      • 1 RestructureConditionIntensityResults(…)
      • 1 RestructureConditionResults(…)
      • 1 RestructureCspResults(…)
      • 1 RestructureHspResults(…)
    • 5 was not granted run permission by the scheduler:
This progress looks :frowning: because there were failed tasks"
The daylight factor component is also giving a similar errors which I think are related to radiance
I intalled the new version (1.48.25) from Pollination and even the sample files are giving errors
what should I do to fix these ?
These are my versions (who got installed automatically with Pollination )
Thank you
Were you able to fix this error? I had the same problem and my LBT is updated to the latest version, but I still have the error…
Hello ! Yes, the problem was that my username had an accent in it “é” , and Radiance probably didnt like that
