I’ve been trying to use the morpho plugin to generate ENVI-met .inx files. I’ve been doing it successfully quite a number of times but on my new project an error occurs with the soils when I create the .inx.
Here is what the soils look like in my Rhino model:
And here is what they look like in the generated inx model:
I never encountered this especially considering that I drew the soils so that they match the grid:
Do you know about this problem? What could be the cause?
Thanks in advance.
Julien
