Dear all,
For some reason whenever Iopen a HB file an error sign “You should first let Honeybee to fly” always appears on the “Honeybee_ListZonePrograms” and “Honeybee_Call from EP Construction Library” tabs although the HB and LB tabs have always been on the canvas. (Attached are the screen shots)
Whenever I reconnect the tabs they run ok but I am sure this is not what should normally happen.
Does anyone know how I can fix this problem?
Thanks in advance,
Daniel
