Hi everyone,
I’m working with PCM (Phase Change Material) and I wanted to set the HeatBalanceAlgorithm to ConductionFiniteDifference (CFD).
To do this, I connected the following additional string to the “HB Model to OSM” component:
HeatBalanceAlgorithm,
ConductionFiniteDifference;
and
ConductionFiniteDifference; !- Algorithm
However, I received this error:
1. ** Severe ** <root>[HeatBalanceAlgorithm] - Object should have no more than 1 properties.
I’m not sure what is causing this issue.
My goal is to correctly implement the CFD method required for modeling PCMs. Am I formatting the additional string incorrectly, or should this be set elsewhere?
Thanks in advance,
Hamed Sangin
