I’ve been following Chris’ tutorial specifically the Outdoor UTCI tutorial under Ladybug Comfort tutorials and I’m wondering why the comfort mannequin component is getting an error.
I’ve tried both plugging in data from the epw and using plain numbers, both won’t make the mannequin work properly, it’s been displaying “Solution exception: too many values to unpack”.
I think the update failed in your case, because I see some old dates on your components. You should try to update again, but if you are in trouble you could try this procedure (manual update):
