I am just starting with HB+ and LB+ and after updating both I ran into that error. Any Idea what is going wrong?
Many thanks and best regards
Martin
Even I am facing the same issue. Did you find the solution? @martin.klingler @mostapha
No, it’s a pity, nobody seems to have any idea what’s going wrong. I have to forget HB+ at the moment
Hi @martin.klingler…just delete the line no.45 to 52 from the HB+ annual metrics component. After that it will work fine.
Here is what I have done and seems to work also
