I’m trying to run a very simple daylight analysis, but I have an issue with the calcul of daylight autonomy : " 1. Number of points in ill files: -3 doesn’t match the number of points in point files: 3248".
I can’t fix this, can you help me please (file attached)?
The simulation you are running is point in time illuminance. In order to get .ill files for daylight autonomy, you need to run the Honeybee_Annual_Daylight_Simulation instead.
Then you can use the Honeybee_Lookup Daylight Folder component which will give you the location of the .ill files.
