I’m trying to run a simulation using the Dynamic Window Construction, but when I run a simulation I always get a fatal error.
I can’t use the shade element because that only works with single pane glass materials.
I have detailed values (calculated separately) for solar transmittance for the glass system with and without screen and want to use the dynamic window element to switch between the two according to a schedule. But currently I can’t get it to work.
If I use the shade element to enter my screen separately, I’m not sure the resulting solar transmission will be the same as the one we calculated in detail.
