I am getting this error when truing to run the ModelToOSM component:
Runtime error (MissingMemberException): ‘Room’ object has no attribute ‘units’
Traceback:
line 166, in script
Model units are meters
I find no input on any of the components to specify what units Rooms are in . . . I thought everything ran in SI units & meters by defaut. Is this correct?
UUUGH . . . I knew it was something simple that I missed. Thank you Trevor! I’m still getting used to the new version as opposed to legacy version 0.67 . . . I’m sure that’ll solve my issues. But I’ll post back here if any more issues.
Cheers!
That got ModelToOSM component to run by adding the HB Model component (Of course . . . I knew that . . . ), but when I add ApplyLoadVals the Peak Cool Loads go down . . . !?? what have I done? I’m convinced that I’ve missed something else really simple . . . or so I hope . . .
Notice the two image, in the first one both the ModelToOSM and PeakLoads components are running peak load calcs and they are identical with the same input. (I’ll upload that image in another post right after - only letting me upload one image at t time) The second image shows where I add ApplyLoadVals to the ModelToOSM component using the HB Model component, & the loads are reduced . . . ?
Thanks again in advance for any insight you can share . . .
Cheers!
