When I run an image based analysis it works for the older component but with the new component I am receiving an error which I can’t understand (see attached picture)
Image based bug RR 7.14.gh (511 KB)
Can you share the .err file from inside the study folder?
Please find it attached here:
error.txt (440 Bytes)
Thanks. This should not give you an error. I will get this fixed later today or tomorrow.
Mostapha
Roya,
We just realized what the issue is after seeing a few people encouner this in a workshop. When you see the black command line window pop up, DO NOT close it. This is a window indicating that the analysis is running. If you close it, the analysis will stop running before it finishes and you will get the error that you have reported here. If you wait for the window to finish, it will close on its own when the analysis is done.
-Chris
