Error with Radiation Analysis
The file was working just fine before, however upon reopening the file I get this error on the radiation analysis component.
  1. Solution exception:NoneType is not iterable
Although the geometry transformation of the script is not working the way I want to yet.
But the idea behind this is that I am trying to transform the negative space of a lane way to optimize solar radiation on specific faces.
It is still a work in Progress.
I have attached both the gh file. I have also tried this in both the current and past versions of ladybug.
Any help would be much appreciated.
092914_GH.gh (147 KB)
092614_GH.gh (122 KB)
Hi GB, Can you please internalize the geometries so I can check what’s going wrong with your analysis? There is no way that I can tell you what’s is wrong without having your geometry. -Mostapha
Hi Mostapha,
Uploaded are the new files with the internalized data.
The input is just a network of a few crvs however could just be a simple single line.
Thank you for your help.
092914_GH_internalized.gh (143 KB)
092614_GH_internalized.gh (127 KB)
Hi Again GB, Sorry for the late reply. You are using some components in your definition that I don’t have installed. I will try again later today with more plugins installed and will let you know.
