I’m trying to simulate a room that has an external shading device by using an E+ component in GH. I got many errors!!!
please see the photo and the text file.
Hi @rsalelwani,
This issue is about epw weather data.Generally, which means Energyplus cannot locate weather file.
Make sure the weather file directory (Epw path) has no white_space and any special characters. If the issue persists, please share your epw file and the destination that you provided.
Can you share file path as text that you have chosen?
Like this: C:\EnergyPlusV8-8-0\WeatherData\USA_CA_San.Francisco.Intl.AP.724940_TMY3.epw
As you can see, I put the epw file in drive C and there is no white_space_and_any_Special_character in the path.
@rsalelwani, Your path is too long and has some white space. Copy and put the epw file into Energyplus WeatherData folder that I mentioned in previous post and use it for the simulation.
