I’m getting this error from HB AdaptiveMap panel and not sure why. A coworker was able to run it successfully with the same inputs.
I’m running all of the most recent versions of software: LB 1.3.0 and OpenStudio 3.3.0.
Looking at the error reports, it seems like the Adaptive Comfort Map panel is unable to run EnergyPlus successfully. Here are some lines from the error report:
EnergyPlus Starting
2021-11-24 13:30:16 INFO: EnergyPlus, Version 9.6.0-4b123cf80f, YMD=2021.11.24 13:30
2021-11-24 13:30:16 INFO: **FATAL:Errors occurred on processing input file. Preceding condition(s) cause termination.
2021-11-24 13:30:16 INFO: EnergyPlus Run Time=00hr 00min 0.13sec
2021-11-24 13:30:16 INFO: Program terminated: EnergyPlus Terminated–Error(s) Detected.
Not sure if this is helpful, but I get this other error from running an energy simulation (on a simple rectangular box) that I had not had previous to installing the newer OpenStudio. (I had problems with using AdaptiveMap earlier to installing the new version with different errors)
