Dear all,
I am using Point-In-Time View-Based component and using the View-based example file (LB 1.5). If I add customized Radiance parameters, the component always yields an error.
Sichen
Dear all,
Sichen
Hi @SichenLu,
You have to pass Radiance parameters through the HB Radiance Parameter component. The parameters that you add to additional_par_ will replace the default parameters.
Dear Mikkel,
Thanks! It works now.
Sichen
