I was trying to convert a bunch of Breps into HBSurfaces and ran into the following error:
Solution exception:‘NoneType’ object is unsubscriptable
I tried troubleshooting the file by testing Breps individually and found the errors occur in the case of Open Breps (especially those which seem to have lines in them).
Closed Breps and Untrimmed surfaces seem to work fine.
Can anyone point me to a solution/workaround for this ? My gh file with internalized geometry is attached.
Hi @sarith, @MingboPeng
I think I am facing the same problem but your files and pictures can not be loaded it may be for the old forum referring.
Can you help me on this?
