Excel read write Battery
when i use excelreadwrite数据读写.zip (86.9 KB)
Prompt this error:
  1. Solution Exception: Cannot cast a COM object of type “System .__ ComObject” to interface type “Microsoft.Office.Interop.Excel.Application”. The reason why this operation failed was that calling QueryInterface on the COM component of the interface whose IID is “{000208D5-0000-0000 -C000-000000000046}” failed because of the following error: An error occurred while loading the type library/DLL. (The exception is from HRESULT: 0x80029C4A (TYPE_E_CANTLOADLIBRARY)).
How can I solve it,Thanks in advance。
You probably installed a plugin in GH. You need to unblock all of the files that came with that plugin.
@AbrahamYezioro How can I operate it in detail? thank you very much.
For instance see this discussion.
For this instance i unblocked the TT Toolbox files (See location in red frame in the image).
You need to do the same for all items in the plugin you installed.
@AbrahamYezioro Sorry for not seeing the reply in time, thank you very much
