I was following a tutorial online to perform an energy simulation however it used an old version of honeybee/ladybug where the simulator automatically generated an .idf file to send to energyplus (i think). I have installed openstudio however this is the complete error i receive:
I also checked your model. It ran without any fatal errors. please check if the unit in rhino is Meters. You can check this by typing Units in the command line of Rhino.
Hmm okay, I have not changed the units so it could be currently working in millimeters. I don’t have rhino/grasshopper available at home so will check in the morning.
@oscar.perkins and @SoniaPorpiglia The solution stated by @devang works. It is due to mismatch in units. Go to Rhino change the units to ‘meters’. Then open grasshopper and open the .gh file. It solves the problem. I think am certain because I had the same issue today. If anyone has the same issue you may try this. Thanks
