Exporting honeybee plus geometry to OBJ files
Hi all
I’m looking for a way to export my honeybee geometry to an OBJ file. Right now I can only see an option to get the export the Rad file but not the geometry as a whole. My geometry is in a Data format.
Hope you have some ideas on how to do it :slight_smile:
Best regards Rasmus
Why not bake your geometry into the Rhino scene and then export to .obj using Rhino’s exporters?
Hi @Rasmus1422188,
Here an exporter i found on the web.
exportOBJ.ghuser (2.7 KB)
You can also use pancake for a lot of file types.
Only obj files are missing here.
You can use Pancake to export obj files. The component Export As utilizes Rhino’s Export so that most formats should be supported.
