Extract/export hourly energy results to excel
I have successfully ran an energy model using the ModelToOSM component and can visualize results using the LB Hourly Plot and HB Color Rooms component.
I am trying to figure out a way to export the hourly energy results to excel. Does anyone have any pointers?
Thanks for your help!
-Teresa
@t_pnw ,
You can get the list of values associated with any data collection using the “LB Deconstruct Data” component. So you should pass your imported results through that. Then you can use any number of other Grasshopper plugins to write those lists of values into Excel. Personally, I like the Excel writers and readers in the TT Toolbox plugin but I am sure that others on the forum have a number of other good suggestions.
