After installing the latest version of HB and LB- Legacy I noticed an extreme discrepancy in the results I was getting for my heating loads in comparison to the same loads on the same projects with older versions. In order to understand the issue better I set up a script where I have two scenarios.
- I generate simple zones without manually assigning any EP Construction EXCEPT from the glass.
- I decompose the zones from Scenario 1, I assign a very simple EP Construction with low U Values to all Opaque geometries and I keep the same glass EP Construction as Scenario 1.
The results for the heating loads are:
- 65.9 kWh/m^2/year
- 731.9 kWh/m^2/year.
The results for the cooling loads are:
- -1.9 kWh/m^2/year
- -5.5 kWh/m^2/year.
I really can’t figure out what can cause this. I upload the script and a screenshot of my results.
If any one has any idea I would be grateful!
I ran the example for Amsterdam but I had the same issue with other locations as well!
Thank you in advance for your input!
Best
Tasos
