I tried to add interior window by addHBGlz component. Everything went well but the last calculation step. The strange thing is that I could run model with Energyplus calculator. But if running with Open Studio, errors happen. I am wondering if I did something wrong and are there any solutions? Thank you.
Thank you for answering my question again. Actually I tried this way before, but error occured as “index out of range:0” in the last simulation step. Before the last step, everything seems good.
Hi @zouYK,
I think this is because you use the glass material directly as construction input.
You first need to put this material into a construction.
The way you generate the windows is a bit complex. Have a look a the grasshopperfile I sent in this post:
