When I import the file from idf, I got the error said “failed to create geometry”, how could I solve it? Does it works when I switch the idf version or not? And I tried different versions, it was the same error showing there… Also, the window was not punched correctly into the wall, I was wondering what could happened, and some windows were punched into the wall and some were not…Could anyone help please?file1.3dm (226.9 KB) file1.gh (780.9 KB) Office_Buffalo.idf (494.3 KB)
Hi @David1,
I did look at the file. However, I would recommend that you simply the file by keeping only relevant components. The file also wants us to install other plugin.
