Hi everyone,
I am dealing with an issue using honeybee and Radiance. I have successfully run daylight simulation (grid based analysis) but found error when reading the radiance result (using ‘ReadRadResult’). There are 6 figures attached that you can see.
Looks like this is related to ‘AnalysisRecipe’ where I input skyfile based on epw file (GridBasedSimulation). This generates 3 file outputs for analysis recipe and it leads the simulation to produce the number of data exceeding the number of grid cells (three times of gridcells). I found no error when applying DFSimulation for the analysis recipe because it generates only one skypath output (see figure 2)
Actually, I have solved this issue by using item selector to chose one of three outputs produced by ‘genClimateBasedSky’. It works! (see figure 3) But, when I changed to another output of skypath, the results changed by about 20-200 lux (I just noticed some values in panel). This led me to throw this issue in the forum: which skypath is trustable that I can choose? and or whether myworkflow in grasshopper is not correct? (looks like it’s better to use honeybeeplus but I haven’t explored it yet)
Also, the illuminance value produced in my model is too big (see figure 5). Please give me some explanation about this…
Here is I attached my gh file
Latihan 2 radiance daylight factor new.gh (847.7 KB)
