Fail to run butterfly when trying to run outdoor simulation with buoyant force
Hi, everyone!
Please help me with my issue here. I am trying to run outdoorsimulation with buoyant effect, what I did was to asign temperature to every surface of my geometry, which temperature I was planning to get by running Honeybee Surface outter Temperature.
I have been trying to take buoyant effect into account by simply connecting heatTransferReceipe component to Solution, but solution failed to run with the following error message:
and the Plot Residual component had returned error:
1. Solution exception:Failed to load residual fields. Read the warnings above for more details.
The same file seems to run fine with steadyIncompressibleRecipe instead ofheatTransferRecipe, here is my .gh file.
test_airflow_buoyance.gh (481.9 KB)
Please tell what I am doing wrong. Thank you in advance for any suggestions!
Hello
I tried now to run a model similar to your model
did you solve it ?
