Failed to control the indoor temperature using the HVAC system
I would like to seek your guidance on an issue I encountered. When using the HVAC system, I modified the Program based on the template settings. However, after applying my modified Program, the indoor temperature is not well controlled, while using the original template without any changes works very well.
May I ask what might be causing this?
Battery pack
Indoor temperature using the template program.
Indoor temperature using the modified program.
