Hi Everybody.
I’m having some problems trying to connect my HBzone to the OpenStudio component, since, from what I understood, the schedules that I used are not recognized by it.
Despite I followed all the steps that Chris has suggested (I replaced the ‘OpenStudioMasterTemplate.idf’ in my ladybug default folder) I still can’t run the simulation.
These are the errors that occur:
“1. Failed to find DEFAULTCSVPLACEHOLDER in the Honeybee schedule library.”
“1. Solution exception:‘NoneType’ object is unsubscriptable”
How would you think I could manage the problem in my file?
I’m sorry if my question might be trivial for you but I’m still a beginner in the use of the software.
I attached the gh file below.
Thank you very much for your help and your work.
Carlie
EnergyModeling_CS.gh (926 KB)
