Failed to import fairyfly
Hi @chris . thanks for placing Fairyfly
I installed Fairyfly step by step but it seems to be missing from the Ladybug Tools library. All Fairyfly components are facing this error:
  1. Solution exception:
    Failed to import fairyfly:
    No module named fairyfly.shape
Hi @Aliarch ,
It’s pretty clear from your screenshots that your core libraries are not updated to the same level as the LBT 1.10 components. If you have not done so already, I recommend reinstalling via the Pollination single-click installer.
Or, if you are on Mac, you can use the Food4Rhino unistaller.gh with the installer.gh.
