The same issue occurs here. I have all the components in grasshopper but each and every one of them is labeled red with the comment “Failed to import ladybug.” Same also for honeybee or dragonfly components.
I did follow all steps on the installation guidelines for Windows with Rhino closed etc. After the .bat file runs, and even though we receive the following text from the cmd panel “Congratulations! Setting the search path…was successful:” it seems that when compared to the similar screenshot from the installation guidelines MarioAlves and I do not see the following path created (not sure if this gives out any hints of what else we can try):
C:\Users[USERNAME]\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\settings-Scheme__Default.xml
Thanks!
