Hello friends
In the annual daylight imulation in Honey Bee Plus, in this file, I get this error when I change the period analysis:1. Solution exception:Failed to load the results form an empty file: c:\ladybug\hbp_sample_files\gridbased_annual\result/scene…default.ill
Double check inputs and outputs and make sure everything is run correctly.
For example, it works properly in period analysis from 9 to 3 months, but when I change the date, an error is given.
Does anyone know where the problem comes from?
