I’m having a issues generating probes for the butterfly cfd analysis. I’m using the indoor air 2d example file. I’ve re-installed both BF and OF multiple times. The error is:
- Solution exception:Failed to load values:
Failed to find probes folder folder at C:\Users\User\butterfly\indoor_airflow_2d\postProcessing\probes
Any help would be appreciated! thank you!
