Hi @MingboPeng and @chris, I have a problem with the new component DetailedHVAC. When I assign the BaseboardWaterRadC to zone equipment, I get the error “1. Solution exception: Failed to serialize IB_HVACSystem; please report this to the developer!”. I’ll be thankful if you can check if there is a bug here.
There was a bug here: Radiator using Ironbug not working - #2 by mingbo - Grasshopper Plugin - Pollination Discourse, but it is just fixed. Please update the Ironbug and let me know if you have any other issues.
Thanks
Mingbo
Thank you, yes I’ve updated Ironbug and now it works.
Hi @ehsan.anvary let me know if this is related to this issue: HW use equipment - #2 by MingboPeng
Yes, Thank you, this is related to that problem and has been solved.
