Falsecolor2 error
I am getting error when i am trying to convert fc on wxfalsecolor v0.52. Do you have an idea why its happening?
I solved problem, it was about Radiance version. Problem was I setup recent version which is 5.2, after changing from 5.2 to 5.1 everthing solved.
Thank you for posting the answer. I think someone else had a similar issue. It’s good if someone reports this issue on wxfalsecolor repository so it can get fixed at some point. I also remember that I saw a post on Radiance’s GitHub that fixes the problem for the next release but I’m not sure.
Thanks!
This also happened to me.
cheers!
Miru
