Hi!
I’m running an energy simulation for a room with multiple zones and encountered this warning:
Cooling Coil has leaving humidity ratio > entering humidity ratio
Does this warning affect cooling energy consumption? Because the cooling load is unreasonably low compared to when the simulation is run with ideal air load system.
Thanks in advance.
