Hi everyone,
I am trying to simulate a Semi-Transparent Photovoltaic (STPV) system using HB Window Construction Dynamic in Honeybee Energy. My goal is to dynamically switch between 3 different window states (20%, 40%, 60% transmittance) based on an hourly schedule.
However, I am encountering fatal errors that terminate the simulation before it begins. I have tested this on both LBT 1.8.0 and LBT 1.9.0, and both fail but with different error messages.
- The Setup:
Constructions: 3 valid HB Window Construction objects (originally Single Glazing: Glass + Gap + Glass, also tested simplified Single Layer Glass).
Schedule: An hourly integer schedule (0, 1, 2) generated via Python, connected to HB Fixed Interval Schedule with âDiscrete/Modeâ Type Limits.
Assignment: The dynamic construction is assigned directly to the HB Aperture.
- The Errors:
In LBT 1.9.0 : I get a translation error regarding a âGeneric Constructionâ:
** Severe ** [Construction][Generic Construction] - Missing required property âoutside_layerâ.
** Fatal ** Errors occurred on processing input file.
In LBT 1.8.0 (EnergyPlus 23.2): I get a thermal balance initialization failure (temperature explosion):
** Severe ** CalcHeatBalanceInsideSurf: The temperature of -1306304.02 C for zone=ââŚâ, for surface=ââŚâ
⌠is very far out of bounds during warmup.
- Debugging Steps I Have Taken:
Static Test: I disconnected the dynamic component and tested each of the 3 static constructions individually on the aperture. They all work perfectly. This rules out issues with the material or layer definition.
Data Structure: I ensured the _constructions input on the Dynamic component is Flattened**. Param viewer shows 1 branch with 3 items.
Simplification: I removed the Air Gap and Inner Glass, testing only a single-layer PV glass to rule out âmassless layerâ issues. The error persists.
Geometry: The glass thickness was corrected to 6mm (0.006m).
Schedule: Verified the schedule contains only integers (0, 1, 2) and has HB Schedule Type Limits set to Discrete/Mode.
It seems like the Dynamic Construction object is not being correctly translated into the OSM/IDF, or the schedule isnât initializing the state correctly at timestep 0.
I have attached my simplified GH file. Any help or insights would be greatly appreciated!
