Hi Amaraa,
Now I am little bit curious about how the Ladybug_Sunpath Shading (SunpathShading) component works. Does _analysisGeometry input only require PV panel surfaces? It seems like Points and normal Surfaces could also work according to its description.
As you correctly noticed _analysisGeometry input parameter allows supplying both surfaces and points.
Sunpath Shading component actually calculates the shading per each corner point of the supplied surface.
For example: if you supply some rectangular surface to the _analysisGeometry input, it will pick all four corner points of that surface, calculate the annual shading for each one of them, and then calculate their average. That’s the annualShading value of the surface you supplied to the _analysisGeometry input.
Sunpath shading component can also be used to analyse the impact of shading per point. This can be beneficial for solar radiation or comfort studies, where one would supply a grid of points to the _analysisGeometry input.
As you are concerned with Photovoltaics, you do not have to worry about supplying points instead of surfaces. You can, but it’s easier if you supply only the surfaces.
And my main question is that how does Ladybug_Photovoltaics Surface (PhotovoltaicsSurface) take an account of surrounding obstacles which could potentially makes a shade on the analysis geometry.
To account for the shading from the surrounding objects, use the context_, coniferousTrees_ and deciduousTrees_ inputs of the Sunpath shading component. The context_ input requires opaque obstacles (terrain, buildings, houses…) while coniferousTrees_ and deciduousTrees_ ones will account for the transparency of trees. I attached the file below with some internalized obstacles.
In this example, the upper floor geometry will make a shadow on the lower floor of a façade that includes the PV I am going to test. In that case, do I have to connect the upper floor façade geometry as a context_ input? Or does the component itself will understand the whole geometry and calculate shading automatically that it would influence the outputs such as ACenergyPerYear?
This is called self shading.
You do not have to supply the surfaces additionally to the context_ input. The component will “under the hood” add them to the context_ input to account for self shading. Last year this hasn’t been the case, but after the suggestion by Chris Mackey, I changed this feature.
However, as we are using the PV SWH System size component, there will be no self-shading. The PV SWH System size component positions the PV rows in such a way, that no self shading will appear for the given minimalSpacingPeriod_ criteria.
If these explanations were not clear, or if you still have some issues, do not hesitate to reply back.
FindingoptimalsizeofPVingivenarray4.gh (2.73 MB)
