I face the challenge of degenerate surface and air-boundary in non-interzone surfaces.
I would appreciate it if you could kindly let me know how I can detect the degenerate surfaces.
(I used the bake method to generate meshes to make guides for HB to define air boundaries)
Please find the screenshot of the error in the attachment.
Many thanks in advance.
Sincerely,
Behnam
Hi @behnammmohseni, I have the same problem. Do you remember how you have solved this?
Berrak
Hi @berrakbalci
Yes, I remember.
I tried to simplify the geometry using the bake feature. So the feature created after the baked process should be managed carefully. Since at least they share between two sides. It was very exhausting since the geometry was complex but after some hours I got the result. The root of the problem was the AutoCad simplifications of different stories and levels. Air walls and boundaries sharing different elevations are challenging, the nodes and the convexity of the zone should remain.
Sincerely,
Behnam
