Hi
I am a student and I am currently learning how to use ladybug in grasshopper to generate a solar envelope on rhino. I have created a simple model and have used the “CLASS_12_SOLAR_ENVELOPE_ADV” file to test it.
However, it seems that the solar envelope component is ignoring the obstacle curve that I have set up, and just generating a flat envelope at the maximum height above the site as shown below:
As I am a new user, I cannot upload any attachment, please find the google drive link below for my files. I would be very grateful if someone can help to point out have I done incorrectly. Thank you very much.
https://drive.google.com/drive/folders/1h_o_w5qig7KrLTfjL8PeeH4h7BAB5sU2?usp=sharing
Dear Abraham
Thank you so much for your reply! To my understanding (correct me if I am wrong), the solar envelope should indicate the maximum massing volume that I can build on the plot, that it would not block away direct solar access to the existing building (the box at north), this is why I have located the building at north, expecting there will be a “slope” generated on the solar envelope.
But I have tried putting in more blocks at the south of the plot, and it is still generating a flat envelope. Do you think it might be a problem with the script that I am using?
Thanks again for replying!
Calvin
I was probably not concentrated when i replied. You are right. Sorry for the confusion.
I’ll check your file later on.
Tried many things and it didn’t work … until i changed unit to mts. Then it is fine.
Attached.
CLASS_12_SOLAR_ENVELOPE_ADV_AY.gh (431.1 KB)
Untitled_AY.3dm (106.7 KB)
Dear Abraham
Thank you so much!! Would have never thought of changing the unit! I really appreciate it and could not thank you enough!!
Calvin
