Framefactor on Window
Greetings everyone,
Does anyone know how to make a percentage frame factor for a window in Grasshopper? I have used the scale function, but this does not give me an procentage frame factor for the whole window.
I also used the “Honeybee_Glazing based on ratio”, but can not join the surfaces as one HBzone afterwards.
<a class=“attachment”
How can i make this the other way around?
href="/uploads/default/original/2X/3/3f68d95d67a51d25e26ad08873322aaed14695f6.gh">Framefactor.gh (5.4 KB)
Best regards
Tobias
I don’t fully understand your workflow based on your image.
Nonetheless, you’d have to scale with a square root of your factor in order to get the correct geometry.
V
Hello @vhoang, thank you for your quick reply.
This is exactly what i was looking for. Thank you so much!
Kind regards.
