I just ran into this problem when running the simulation using OpenStudio in From_buildings_solids sample file.
I previously used URBANopt and it did not show any error. Could you explain to me what could be wrong?
Hi @BardoSalgado,
This is a geometry problem. When geometries have small inaccuracies this problem occures. When you look at the output: “report” you can see which zone or zones are causing the problem.
