Fullforcing df envimet - can't write the fox file
Hello, while writing the .fox file with dfenvimet, an access violation issue occurs, so it is impossible to run the simulation with fullforcing. Any Help? Thank you in advance!
I solved creating a .fox file, named as the epw file, with the envimet forcing manager and placing it inside the reference morphomodel folder, after that, when connectiong “folder” and “epw” at the fullforcing component it runs normally and the simulation as well. Hope it could be usefull. Cheers!
Hi @Gmm
I have the same issue with Morpho plugin full forcing which doesn’t run. Could you please advise me how to fix the problem? Thank you in advance.
